August 29, 2024 at 2:57 pm
emmanouil.trachanas
SubscriberHello,
I am simulating a transient heat flux due to a laser pulse with a command script on the surface of a slab with transient thermal analysis. Then the idea is to export the thermal heat flux to LS Dyna in order to do the structural simulation (as I want to use the non reflecting boundaries that only LS-Dyna has to avoid the reflections of elastic waves and therefore reduce the simulation domain). I am using ANSYS 2024 R1 and I saw that the import load was introduced to LS-Dyna, Has anyone performed a similar type of analysis? as I am having trouble importing the load,
thank you for all your help
Kind regards
Emmanouil
September 2, 2024 at 7:41 am
Sampat Kumar
Ansys EmployeeHello Emmanouil,
It seems you've posted a duplicate question on the forum. I'll close this one to avoid confusion. Please continue the discussion using the following link.
Coupled Workbench Transient Thermal Analysis with LS-Dyna (ansys.com)
https://innovationspace.ansys.com/forum/forums/topic/coupled-workbench-transient-thermal-analysis-with-ls-dyna/
Best Regards,
Sampat
6044
