March 1, 2024 at 8:46 am
vikram chahal
Subscriberi am doing coupled simulation of vehicle and fluid tank. In which i am trying to interact the vehicle bouncing and pitching motion to fluid tank and vice versa in fluent using udf. but during the interpretion of UDF i am getting parse error. can you suggest where changes are required. below is the udf:ÂÂ#include "udf.h"#include "thread.h" // Include the thread header fileDEFINE_EXECUTE_AT_END(coupled_simulation){  real simulation_time = 0.0;  real dt = 0.5; // Time step size  real end_time = 4.0; // End time of simulation   Define vehicle parameters  real m_truck = 2000.0; // Mass of the truck (kg)  real I_truck = 5000.0; // Moment of inertia of the truck (kg*m^2)  real k1 = 2.86e10; // Front spring stiffness (N/m)  real k2 = 3.870e5; // Rear spring stiffness (N/m)  real l1 = 0.2; // Distance of front axle from CG (m)  real l2 = 0.8; // Distance of rear axle from CG (m)  real F_braking = -10000.0; // Braking force (N)  // Define fluid parameters  real fluid_density = 1000.0; // Density of the fluid (kg/m^3)  real fluid_velocity_x = 0.0; // Initial fluid velocity in x-direction (m/s)  real fluid_velocity_y = 0.0; // Initial fluid velocity in y-direction (m/s)  real fluid_velocity_z = 0.0; // Initial fluid velocity in z-direction (m/s)  // Initial conditions for vehicle motion  real x = 0.0; // Initial vertical displacement  real theta = 0.0; // Initial angular displacement  real x_dot = 0.0; // Initial vertical velocity  real theta_dot = 0.0; // Initial angular velocity  // Main simulation loop  while (simulation_time < end_time)  {    // Step 1: Calculate vehicle response to braking force    real x_ddot = (-k1 * (x - l1 * theta) - k2 * (x + l2 * theta) + F_braking) / m_truck;    real theta_ddot = (-k1 * l1 * (x - l1 * theta) + k2 * l2 * (x + l2 * theta)) / I_truck;    x_dot += x_ddot * dt;    theta_dot += theta_ddot * dt;    x += x_dot * dt;    theta += theta_dot * dt;    real simulation_time = CURRENT_TIME + dt;    // Step 2: Apply vehicle response to fluid tank and compute fluid forces and moments    real fluid_force_x = 10.0;    real fluid_force_y = 0.0;    real fluid_force_z = 0.0;    real fluid_moment_x = 0.0;    real fluid_moment_y = 5.0;    real fluid_moment_z = 0.0;    Thread *t;    face_t f;    cell_t c;    /* Loop over all cells */    begin_c_loop(c, t)    {      /* Loop over all faces of the cell */      real A[ND_ND], F[ND_ND];      real p = C_P(c, t); // Pressure of the cell      C_CENTROID(A, c, t); // Centroid of the cell      int i;      for (i = 0; i < ND_ND; i++)      {        F[i] = 0.0; // Initialize force vector      }      /* Loop over all faces of the cell */      for (i = 0; i < THREAD_NFACES(t); i++)      {        f = C_FACE(c, t, i);        F_AREA(A, f, t); // Face area vector        /* Calculate face force */        int j;        for (j = 0; j < ND_ND; j++)        {          F[j] += p * F_AREA(A, f, t)[j]; // Pressure force on face        }      }      /* Accumulate forces and moments */      fluid_force_x += F[0];      fluid_force_y += F[1];      fluid_force_z += F[2];      fluid_moment_x += (A[1] * F[2] - A[2] * F[1]);      fluid_moment_y += (A[2] * F[0] - A[0] * F[2]);      fluid_moment_z += (A[0] * F[1] - A[1] * F[0]);    }    end_c_loop(c, t)    // Step 3: Update vehicle motion based on fluid forces and moments    Excitation force = fluid force    x_dot += fluid_force_x / m_truck * dt;    theta_dot += fluid_moment_y / I_truck * dt;    x += x_dot * dt;    theta += theta_dot * dt;    simulation_time +=dt;    // Step 5: Output results if needed    // printf("Time: %.2f, x: %.4f, theta: %.4f\n", simulation_time, x, theta);    // Step 6: Check termination condition    if (simulation_time >= end_time)      break;  }} -
March 1, 2024 at 9:53 am
Forum ModeratorCompile the code, not all functions are available in the Interpreted mode. I won't be debugging code, but if you give some clues where the error is I can have a brief look.Â
March 4, 2024 at 8:04 am
vikram chahal
Subscribereal fluid_force_x = 10.0;Â Â Â Â real fluid_force_y = 0.0;Â Â Â Â real fluid_force_z = 0.0;Â Â Â Â real fluid_moment_x = 0.0;Â Â Â Â real fluid_moment_y = 5.0;Â Â Â Â real fluid_moment_z = 0.0;Â
    Thread *t;    face_t f;    cell_t c;Â
    /* Loop over all cells */    begin_c_loop(c, t)    {showing error in step 2 of this code line 44,45,46,47,48,49, 51,52,53 for real fluid force and moments in x,y,z direction showing parse error and line 56 showinfg t as undeclared variable.
March 4, 2024 at 8:00 am
vikram chahal
Subscriberreal fluid_force_x = 10.0;Â Â Â Â real fluid_force_y = 0.0;Â Â Â Â real fluid_force_z = 0.0;Â Â Â Â real fluid_moment_x = 0.0;Â Â Â Â real fluid_moment_y = 5.0;Â Â Â Â real fluid_moment_z = 0.0;Â
    /* Loop over all cells */    begin_c_loop(c, t)    {showing error in step 2 for real fluid force and moments in x,y,z direction showing parse error and showinfg t as undeclared variable. -
March 4, 2024 at 10:03 am
Forum ModeratorOK, a parse error may be syntax related, so look in the few lines above the one reported in the error. But, if t (thread in your case?) is showing an error, where is that defined? DEFINE_EXECUTE_AT_END doesn't pass the thread so you need to tell the solver what it is.Â
March 26, 2024 at 8:15 am
vikram chahal
Subscriber#include "udf.h"#include// Include the standard I/O library for file operations DEFINE_ADJUST(coupled_simulation1, d){  real simulation_time = CURRENT_TIME; // Get the current simulation time  real dt = RP_Get_Real("flow-time-step"); // Get the flow time step  real end_time = RP_Get_Real("flow-time-end"); // End time of simulation  real braking_duration = 2.0; // Duration of braking force (seconds)  // Open file for writing  FILE *fp;  fp = fopen("E:\coupled trial 3\50 prcnt_files\dp0\FFF\Fluent\libudf6\result\simulation_results.txt", "w");  if (fp == NULL) // Check if file was opened successfully  {    Message("Error opening file.\n");    return -1; // Exit initialization function  }  Domain *domain = Get_Domain(3); // Replace 1 with the appropriate domain ID  if (!domain)  {    Message("Error: Unable to obtain domain.\n");    fclose(fp); // Close the file before returning    return -1; // Exit initialization function  }  // Define vehicle parameters  real m_truck = 5450.0; // Mass of the truck (kg)  real I_truck = 5000.0; // Moment of inertia of the truck (kg*m^2)  real k1 = 2.86e10; // Front spring stiffness (N/m)  real k2 = 3.870e5; // Rear spring stiffness (N/m)  real l1 = 0.2; // Distance of front axle from CG (m)  real l2 = 0.8; // Distance of rear axle from CG (m)  real F_braking = 27000.0; // Braking force (N)  // Define fluid parameters  real fluid_density = 1000.0; // Density of the fluid (kg/m^3)  // Initial conditions for vehicle motion  real x = 2.0; // Initial vertical displacement  real theta = 2.0; // Initial angular displacement  real x_dot = 0.0; // Initial vertical velocity  real theta_dot = 0.0; // Initial angular velocity  real fluid_force_x, fluid_force_y, fluid_force_z, fluid_moment_x, fluid_moment_y, fluid_moment_z;  Thread *t;  cell_t c;  face_t f;  // Main simulation loop  while (simulation_time < end_time)  {    // Step 1: Calculate vehicle response to braking force    real F_brake = (simulation_time < braking_duration) ? F_braking : 0.0; // Apply braking force only within the braking duration    real x_ddot = (-k1 * (x - l1 * theta) - k2 * (x + l2 * theta) + F_braking) / m_truck;    real theta_ddot = (-k1 * l1 * (x - l1 * theta) + k2 * l2 * (x + l2 * theta)) / I_truck;    // Step 2: Apply vehicle response in terms of x(t) and theta(t) to fluid domain as a body force in the source term    real vehicle_force_x = 0.0; // Body force in x-direction  Â    real vehicle_force_y = 0.0; // Body force in y-direction    real vehicle_force_z = 0.0;  // Body force in z-direction    real vehicle_moment_x = 0.0; // vehicle moment in x-direction    real vehicle_moment_y = 0.0; // vehicle moment in y-direction    real vehicle_moment_z = 0.0; // vehicle moment in z-direction    // Update the body force components based on vehicle response    // For simplicity, assuming all the force acts in the z-direction    vehicle_force_y = -m_truck * x_ddot;    vehicle_moment_z = -k1 * l1 * (x - l1 * theta) + k2 * l2 * (x + l2 * theta);    // Apply the body force to the fluid domain    t = Lookup_Thread(domain, 3); // Assuming FLUID_THREAD_ID is the ID of the fluid thread    thread_loop_c(t, d)    {      C_UDMI(c, t, 0) = vehicle_force_x;      C_UDMI(c, t, 1) = vehicle_force_y;      C_UDMI(c, t, 2) = vehicle_force_z;     Â       // Apply the moment components based on vehicle response      // Here, we'll assume all the moments act around the z-axis      C_UDMI(c, t, 3) = 0.0; // Moment about x-axis      C_UDMI(c, t, 4) = 0.0; // Moment about y-axis      C_UDMI(c, t, 5) = vehicle_moment_z; // Moment about z-axis    }    // Step 3: Calculate fluid forces and moments    fluid_force_x = 0.0;    fluid_force_y = 0.0;    fluid_force_z = 0.0;    fluid_moment_x = 0.0;    fluid_moment_y = 0.0;    fluid_moment_z = 0.0;    // Loop over fluid cells    thread_loop_c(t, d)    {      begin_c_loop(c, t)      {        real A[ND_ND], F[ND_ND], F_area[ND_ND];  // Add F_area vector to store face area        real p = C_P(c, t); // Pressure of the cell        C_CENTROID(A, c, t); // Centroid of the cell        for (int i = 0; i < ND_ND; i++)        {          F[i] = 0.0; // Initialize force vector        }        // Loop over faces of the cell using C_FACE macro        for (int f = 0; f < C_NFACES(c, t); f++)        {          face_t face = C_FACE(c, t, f);          F_AREA(F_area, face, t); // Face area vector          // Calculate face force          for (int j = 0; j < ND_ND; j++)          {            F[j] += p * F_area[j]; // Use F_area instead of calling F_AREA macro multiple times          }        }        // Accumulate forces and moments        fluid_force_x += F[0];        fluid_force_y += F[1];        fluid_force_z += F[2];        fluid_moment_x += (A[1] * F[2] - A[2] * F[1]);        fluid_moment_y += (A[2] * F[0] - A[0] * F[2]);        fluid_moment_z += (A[0] * F[1] - A[1] * F[0]);      }      end_c_loop(c, t);    }    // Step 4: Update vehicle response based on fluid forces and moments as excitation force on vehicle equations    x_dot += fluid_force_y / m_truck * dt;    theta_dot += fluid_moment_z / I_truck * dt;    x += x_dot * dt;    theta += theta_dot * dt;    // Update simulation results in the file    fprintf(fp, "%.4f, %.4f\n", x, theta);   Â    printf("Time: %.2f, x: %.4f, theta: %.4f\n", simulation_time, x, theta);    // Increment simulation time    simulation_time += dt;  }  // Close the file after simulation  fclose(fp);  return 0; // Successful initialization}now this code is getting compiled and hooking, but during simulation i am getting very low value of force in order of 0.4 N. i have doubt regarding macro i have used. could you please suggest me use of define_adjust macro is suitable for this coupled simulation or not?? -
March 26, 2024 at 11:39 am
Forum ModeratorHow are you adding the force to the fluid cells?Â
March 27, 2024 at 4:12 am
vikram chahal
SubscriberIN THIS WAY , PLEASE SUGGEST IF ANY CHANGES ARE REQUIRED
 // Apply the body force to the fluid domain    t = Lookup_Thread(domain, 3); // Assuming FLUID_THREAD_ID is the ID of the fluid thread    thread_loop_c(t, d)    {      C_UDMI(c, t, 0) = vehicle_force_x;      C_UDMI(c, t, 1) = vehicle_force_y;      C_UDMI(c, t, 2) = vehicle_force_z;     Â       // Apply the moment components based on vehicle response      // Here, we'll assume all the moments act around the z-axis      C_UDMI(c, t, 3) = 0.0; // Moment about x-axis      C_UDMI(c, t, 4) = 0.0; // Moment about y-axis      C_UDMI(c, t, 5) = vehicle_moment_z; // Moment about z-axis    } -
April 2, 2024 at 12:34 pm
Forum ModeratorThat adds the values to a UDM, it doesn't do anything to the solution.Â
April 4, 2024 at 6:55 am
vikram chahal
SubscriberThanks a lot Rob...
could you please tell how can i apply moment to a tank about z-axis that pass throug CG in ansys fluent.
April 4, 2024 at 10:59 am
Forum ModeratorThat'll be DEFINE_SOURCE assuming you don't want to actually move the body around. Note, if the whole domain moves you don't need to remesh.Â
April 5, 2024 at 8:41 am
vikram chahal
Subscribercould you please provide the UDF code. i have write this oneÂ
#include "udf.h"DEFINE_SOURCE(moment_source, c, t, dS, eqn){  real time = CURRENT_TIME; // Get the current simulation time  real moment = 0.0; // Initialize moment to zero  real CG[ND_ND]; // Center of gravity coordinates  real cellCG[ND_ND]; // Cell center coordinates  C_CENTROID(CG, c, t); // Get CG of the domain  C_CENTROID(cellCG, c, t); // Get cell center coordinates  real distance_from_CG = cellCG[2] - CG[2]; // Distance along z-axis  /* Check if time is within the specified duration */  if (time <= 2.0)  {    /* Apply moment only to cells at CG */    if (distance_from_CG = 0.0)    {      moment = 5000.0; // Apply 5000 Nm moment  }  dS[eqn] = 0.0; // Reset the source term  return moment; // Return the moment as the source term}and hooked as the souce term of fluid domain under cell conditions.
April 5, 2024 at 6:13 am
vikram chahal
SubscriberÂ
April 5, 2024 at 7:01 am
vikram chahal
Subscriberwhere should i hook this UDF?
April 5, 2024 at 10:20 am
Forum ModeratorSource terms are hooked into the cell zones.Â
April 5, 2024 at 10:27 am
vikram chahal
Subscriber#include "udf.h"DEFINE_SOURCE(moment_source, c, t, dS, eqn){  real time = CURRENT_TIME; // Get the current simulation time  real moment = 0.0; // Initialize moment to zero  real CG[ND_ND]; // Center of gravity coordinates  real cellCG[ND_ND]; // Cell center coordinates  C_CENTROID(CG, c, t); // Get CG of the domain  C_CENTROID(cellCG, c, t); // Get cell center coordinates  real distance_from_CG = cellCG[2] - CG[2]; // Distance along z-axis  /* Check if time is within the specified duration */  if (time <= 2.0)  {    /* Apply moment only to cells at CG */    if (distance_from_CG = 0.0)    {      moment = 5000.0; // Apply 5000 Nm moment  }  dS[eqn] = 0.0; // Reset the source term  return moment; // Return the moment as the source term}and hooked as the souce term of fluid domain under cell conditions.
this UDF is giving very less value of force... could you please check it whether syntex and logic is correct or not.
April 5, 2024 at 10:53 am
Forum ModeratorYou're returning a source at the centre position by the looks of it? I'm not able to check code, only point you at the manual.Â
- The topic ‘coupled simulation of vehicle and fluid tank’ is closed to new replies.
5709
