Could you provide the procedure to run Ansys Structure V241 on Linux VDI.
September 16, 2024 at 8:13 am
Jadhav,Rangnath
SubscriberCould you provide the procedure to run Ansys Structure V241 (Mechanics enterprise) on Linux VDI.
September 18, 2024 at 8:05 am
Masataka Nakamura
Ansys EmployeeHi JADHAVR, Thank you for reaching out. Currently Ansys Gateway does not support deploying Ansys Structure V241 on Linux VDI. If you want to use Ansys Structure V241 on a Linux VDI you will need to install it manually.
- Ansys Gateway – Application Support – 2024R1
- The topic ‘Could you provide the procedure to run Ansys Structure V241 on Linux VDI.’ is closed to new replies.
