November 10, 2022 at 9:34 am
November 10, 2022 at 9:41 am
Devendra Badgujar
Forum ModeratorHello Roberto
Let me check and get back to you.Â
Regards.Â
November 10, 2022 at 9:59 am
Devendra Badgujar
There does not seem to be any issue with customer's email address. Can you add the URL to the "allowed" list of sites under Cookies settings and see if that helps? Also, can they try logging in using incognito mode?
Please refer this article Preventing Discovery account login issues - Knowledge Base - Ansys Discovery Forum and see if that resolves the issue.Â
Regards.Â
November 10, 2022 at 10:11 am
Roberto
SubscriberHello Devendra Badgujar I have already done these tests, it does not seem caused by a browser or network problem as I have tried it on the PCs of my company where access to everything is allowed.
Try to access the ansys account with the email I sent you and the error will also come out to you
Let me knowRegards
November 10, 2022 at 10:19 am
Devendra Badgujar
Forum ModeratorRobertoÂ
Thanks for the update. I will test and report it to the concerned team.Â
Regards.Â
November 10, 2022 at 10:55 am
Devendra Badgujar
Forum ModeratorHi Roberto
Is the customer using VPN which might have change their location resulting in the error to log in?
Please try log in without VPN and check.Â
Regards.Â
November 10, 2022 at 11:06 am
Roberto
I just asked the customer and the VPN may have been used 2 years ago, but now it hasn't been used anymore.
is it possible to reset the data to make the license work now?Regards
November 10, 2022 at 11:44 am
Devendra Badgujar
Could you please try clearing your browser chache? In the meantime, I can check with my team to get more information on the error.
November 15, 2022 at 8:49 am
Roberto
I forgot to answer you, yes the problem is solved
Regards
November 10, 2022 at 11:53 am
Roberto
SubscriberHello Devendra Badgujar let me know what the team will say, tomorrow morning I will try to clear the client's browser cache, but I don't think it's because of that as the account doesn't work on other PCs and even from the phone
Regards
November 11, 2022 at 3:00 am
Roberto
The license does not work even if you delete cache
Regards
November 11, 2022 at 4:06 am
Devendra Badgujar
I am checking with the team, will get back to you.Â
Regards.Â
November 11, 2022 at 5:10 am
Devendra Badgujar
Can you access the ''Need help'' link shown below and see if any solutions help. Also, can you confirm if the new PC was bind to another account previously?
Regards.
November 11, 2022 at 5:18 am
Roberto
SubscriberCiao Devendra Badgujar
I tried to read but there is no solution, can't you reset the license?
If it doesn't go if I create a new ansys account and license it do you think this will work?
Regards
November 11, 2022 at 5:23 am
Devendra Badgujar
Let me get more information from the team, will keep you updated. Thank you!
November 11, 2022 at 7:17 am
Devendra Badgujar
We have enabled the user's account, please ask the user try log in.Â
Let me know if the problem persists.
Regards.
- The topic ‘Could not enter account’ is closed to new replies.
3492
1057
1051
965
942
