TAGGED: E-glass-fibre, glass-fibre, material-designer, resin
September 19, 2021 at 3:36 pm
sadiqamin475550
SubscriberWhen I am running Material designer in Ansys workbench, everything is going fine but when I am solving to get results in Material Designer it is showing "Could not connect to SolverProxy". When I run it on my Friends PC it works fine. Please guide. Thank you! -
October 26, 2021 at 12:55 pm
George Karnos
Ansys Employee@shinwari
Try running with your firewall disabled.
If that doesnt work, what Operating system are you using?
Can you post the latest Workbench log file from:
%TEMP%\Workbenchlogs
Please post the content of the log as we are not permitted to open files.
- The topic ‘Could not connect to Solver Proxy in Ansys Material Designer’ is closed to new replies.
1494
1375
1197
