January 19, 2023 at 8:15 am
Luca Schnell
SubscriberHello everyone, i am working on a project where i have to simulate the measured residual stresses and i would like to get some feedback to make sure that i am doing this correctly according to your opinion. I proceed as follows:
- I am exporting the point cloud from FEM
- Then i assign each point with σ XX, σ YY and τ XY
- I reimport the extended point cloud to Ansys
- I define it as initial stress
- Lastly i use a Remote Displacement on my object so it is free to deform due to residual stresses.
Thank you in advance
Luca
January 21, 2023 at 2:56 am
peteroznewman
SubscriberHow are the residual stresses measured?
Here is how I simulate residual stress:
- Create a material that uses one of the Plasticity material models such as Bilinear Kinematic Hardening.
- Create support boundary conditions.
- Apply sufficient load to the intital geometry to cause the material to exceed the yield strength.
- Remove the load.
- Plot the residual stress.
- Plot the residual deformation.
January 16, 2024 at 5:03 pm
Amin Lotfiani
SubscriberDear Peter,
I am trying to find the residual stress in a bent sheet metal. Could you also explain how I can calculate the residual stress or plot it as you mentioned above in step 4?
Thank you in andvance!
Kind regards,
Amin
January 16, 2024 at 5:59 pm
peteroznewman
SubscriberDear Amin,
Use a 2 step analysis and make sure you have turned on Large Deflection.
In the Tabular data for the Force, step 1 will have a value for the applied force such as 820.0 units and step 2 will have a value of 0.0
Insert a Von Mises Equivalent Stress plot. By default, the stress will show the results at the end of step 2. Any component of stress plotted at the end of step 2 is residual stress.
You can insert another result such as Plastic Strain to show that yielding has occured at the end of step 1.
-Peter
January 16, 2024 at 6:07 pm
Amin Lotfiani
Subscriberthanks a lot for the instruction!
I wasn't sure that that the end stress is in fact the residual stress.Â
Kind regards,
Amin
- The topic ‘Correct way to simulate residual stresses?!’ is closed to new replies.
5014
1682
1387
1248
