March 4, 2022 at 1:56 pm
stevenfarm
SubscriberMarch 4, 2022 at 9:53 pmpeteroznewman
In the future, please post your images into your discussion using the Image button rather than attaching a file. ANSYS employees are not permitted to download attachments.
In ANSYS Mechanical, in a Static Structural analysis, there is a Support called Remote Displacement. Select the face at the base of one leg and click Remote Displacement. There are 6 DOF where you can enter 0 to fix 3 translations and 3 rotations. The point will automatically have been placed at the center of the selected face, so in the Details window, type in new X, Y, Z coordinates for location of the Remote Point. Finally, there is a line item called Behavior. By default is it Deformable, change that to Rigid. Repeat on the other leg.
You said you only want to constrain translations in X, Y and Z at the clamp points. For a 3D model, that is not enough constraints to prevent rigid body motion. The structure will be able to spin around the two points. If you have 3 or more non-collinear points, you can prevent the spinning. Or you can apply a zero rotation at one or both of the two clamp points.
Viewing 1 reply thread- The topic ‘Correct way of bearing (Rigid Virtual Part)’ is closed to new replies.
5884
1306
