Correct output of BOUNDARY_HEAT_FLUX(f, thread) in fluent UDF
    • yadukrishnan
      What does the function BOUNDARY_HEAT_FLUX(f, thread) returns in a UDF used in fluent. Wall heat flux density(W/m2) or wall heat (W) ? Does it return total heat flux? To access local heat flux density(W/m2) of a single cell, How can I use this function?
    • DrAmine
      It returns the total heat rate: it is a only available on external boundaries.
    • DrAmine
      for each facet of the eligible boundaries.
    • DrAmine
      ­ƒæì
  • The topic ‘Correct output of BOUNDARY_HEAT_FLUX(f, thread) in fluent UDF’ is closed to new replies.
