November 5, 2020 at 7:42 am
Roberto
SubscriberHello
Sometimes there are problems in the sheet metal conversion, it does not create the spokes, can I send you a file for safe links?
I will also attach a video.
The steps are as follows
1) I try to convert it to sheet metal but I can't create the bends
2)Â I copy the outer surface and create a manual radius for each crease after which the convert is working
Why doesn't it work in the first steps?Â
Best Regards
November 6, 2020 at 8:19 am
subashni.satish
Forum ModeratorHello Roberto
I will share with you Secure Transfer link via email. Please share the model and the video so that I can investigate this issue.
November 12, 2020 at 10:30 am
Roberto
SubscriberSubashni Hello
were you able to see the files?
Best Regards
November 17, 2020 at 7:52 am
subashni.satish
I was able to create the bends by clicking on the outer side. Please check the attached geometry.Â
November 17, 2020 at 8:19 am
Roberto
SubscriberHello Subashni
problem that as you unfolded it to you is not good because SpaceClaim does not explain it correctly
https://www.screencast.com/t/gSsfBmoBgK
If possible can you remove the file from the forum?
ThanksÂ
Best Regards
November 17, 2020 at 2:24 pm
subashni.satish
I apologise, I have removed the model.Â
Unfold works based on the neighbouring faces. In the video, you have shown, I see that the selected face is unfolded in line with the neighbouring face, which is the expected behaviour-
November 18, 2020 at 1:57 pm
Roberto
The correct method of unfolding the piece must be this, completely flat
Best Regards
This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsÂ
November 20, 2020 at 11:27 am
Roberto
were you able to see the video?
Best Regards
November 17, 2020 at 3:13 pm
Roberto
no problem for the file , when I use the unfolded command the component should be completely flat , otherwise the overall dimensions would be incorrect.
maybe I misunderstood?
Best Regards
December 11, 2020 at 8:18 am
Roberto
SubscriberHello
I have not received a reply regarding the problem anymore
Best Regards
December 18, 2020 at 8:37 am
Roberto
SubscriberSubashni
January 8, 2021 at 11:08 am
Roberto
SubscriberHello Subashni Charudatta Bandgar
I am waiting for an answer
Best Regards
January 8, 2021 at 11:13 am
subashni.satish
I will file a bug for this issue and share the bug number with you.
January 8, 2021 at 11:25 am
Roberto
SubscriberHello Subashni Thank you very muh
January 8, 2021 at 12:12 pm
subashni.satish
Forum ModeratorRoberto
BUG number 390517
- The topic ‘Converting to sheet metal’ is closed to new replies.
5849
