3D Design
3D Design
Convert sketch to “Create Layout Curves”
    • Sam Fares
      i drew this sketch below in spaceclaim without check marking " Create layout curves" in the options side. if i switch to 3D, i will have surfaces. I want curves only. Is there a way to convert it to "Create layout curves" so i wont have surface when i switch to 3D?
      Sam
      You can't click "Create layout curves" after you start.  You have to return to 3D, delete the surfaces, and start over on a new sketch with the Create layout curves selected at the beginning.
    • Sam Fares
      Thanks Peter!
  • The topic ‘Convert sketch to “Create Layout Curves”’ is closed to new replies.
