September 27, 2023 at 11:02 am
Pawan Tiwari
SubscriberWhat is the procedure to convert .pjt file to .aedt file?
September 28, 2023 at 6:40 pm
HDLI
Ansys EmployeeHello Pawan,
    The .pjt folder is temporary folder for simulation, that you could not open in Maxwell.Â
    Please find correct .aedt file. Thanks.
HDLI
- The topic ‘Conversion of Ansoft Maxwell .pjt file to Ansys .aedt file’ is closed to new replies.
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Rectangular Coil in Maxwell for WPT using solid block
- Magnetic Dipole moment calculation
1494
1386
1209
