April 30, 2020 at 6:02 pm
inouzil
SubscriberGreetings,
I need some assistance in generating a 2D surface from STL. I extracted the STL from a 2D machining simulation in explicit dynamics. But I am unable to convert it to a surface body. Kindly assist. below is the image of the STL. I have also attached the STL file.
I also used the direct way of exporting the deformed geomtery as below (Linked the solution of model and exported geometry as pmdb file). But it results in very distorted surface and not possible to manipulate in any way.Â
Kindly assist. I am using ANSYS 2019R2
Gratitude for the support.
Regards
Ibrahim Nouzil
April 30, 2020 at 6:05 pm
inouzil
SubscriberGreetings,Â
For some reason the 'attach' option is not working. I can share the STL file if anyone wants to give a try.Â
Regards
Ibrahim Nouzil
April 30, 2020 at 7:54 pm
peteroznewman
SubscriberGreetings Ibrahim,
Put your STL file into a ZIP file. ZIP files are permitted for attachment, STL files are not permitted.
Peter
April 30, 2020 at 10:13 pm
inouzil
SubscriberThank you Peter. I have attached Zip file to previous post. It would be great if you could help out with my problem.Â
Regards
Ibrahim Nouzil
May 1, 2020 at 5:51 pm
peteroznewman
SubscriberI looked at the STL file. It is a big mess. I suggest you just use the STL as a background image and sketch new geometry over that image.
May 2, 2020 at 5:33 pm
inouzil
SubscriberHi.. Thank you Peter for your quick reply. I actually have done the same in Design Modeler, sketched over it but the result was not very accurate and gave me many errors. Maybe will have to try it in solid edge or other CAD.Â
Peter, how did you come to the conclusion that the STL file is 'messed up'? I directly exported it from the deformed geometry in explicit dynamics.Â
Regards
Ibrahim Nouzil
May 3, 2020 at 12:23 am
peteroznewman
SubscriberThere are multiple facets over the same element.
Maybe the code for STL export only works for 3D elements and it fails spectacularly for 2D bodies.
May 5, 2020 at 7:25 pm
inouzil
SubscriberThank you Peter. Appreciate it.Â
- The topic ‘Conversion of 2D STL file to 2D Surface’ is closed to new replies.
4708
1565
1386
1242
.jpg?width=690&upscale=false)
