convergence problem for super critical fluid accessed from NIST data base
    • ANKITAPUJAHARI
      I am using supercritical co2 from NIST database to study natural convection in an enclosure.  I have used density-based solver using implicit formulation and the flux type is Roe-FDS. I am starting the simulation from first order. The convergence rate is very slow. What should be done to increase the convergence rate?
      Thank You.
    • Amine Ben Hadj Ali
      Why density based solver? Any reasons for that?
      Smaller time steps could be helpful there. Do not forget to switch on gravity.
    • ANKITAPUJAHARI
      Density-based solver is because of the dependence of density on both temperature and pressure near supercritical temperature and pressure . I have tried using the pressure-based coupled scheme but the probe values are oscillating. One more thing, when I used constant temperature condition on the cold wall convergence resulted. But after using convective boundary condition the convergence rate is extremely slow. I have used steady-state solver
  • The topic ‘convergence problem for super critical fluid accessed from NIST data base’ is closed to new replies.
