March 3, 2020 at 4:29 pm
MYSELF
SubscriberI am working on fluid mixing using fluent 19.2. in the convergence plot my results do not converge. I observed the straight line after some iterations. I am taking the rms value 10^-6 for continuity, velocities and concentration values for convergence. why it is not converging?? -
March 9, 2020 at 12:20 pm
March 9, 2020 at 2:53 pm
ringelf1
SubscriberIt does not converge because all the lines have to be under your convergence criteria. And when you set all of them up to 10^(-6) the white and the light blue line are below that criteria. and that's why the calculation is still running.
March 9, 2020 at 3:56 pm
Amine Ben Hadj Ali
Ansys EmployeePlease check judging convergence chapter. Better to rely on monitoring key quantities to judge convergence . -
Karthik Remella
AdministratorHello,
I agree with ringlef1. Just to quickly add...
Generally, it is a good rule of thumb to set all your convergence criteria to 1e-6. But sometimes, depending on the problem you are trying to solve, it might be difficult to achieve. You might have to relax your convergence criteria in such cases. A good check would be to see what your monitors are doing. If you are looking for a steady solution and your monitors show this behavior (and your residuals change by at least 3-4 orders of magnitude - i.e., 1 to 10^-3 or 10^-4), then it would seem like you have a decently converged solution.
Thanks.
Best,
Karthik
March 11, 2020 at 5:27 am
MYSELF
Subscriberthank you all for replying me on this problem. it means it will be good if i change my residuals to 1e-4 or 1e-5, then i can get converged solution. Is there any deviation in results?Â
March 11, 2020 at 6:18 am
Amine Ben Hadj Ali
Ansys EmployeeConvergence is not only by decreasing residuals. Have a look into monitor plots and mass and flux imbalances. Default residual criteria are fair but you can tighten them a but this does not however answer the question why they are leveling out so early. Afain: the Manual is your friend.
- The topic ‘Convergence plot’ is closed to new replies.
4989
1670
1386
1243
