Convergence of continuity residual at each time step
    • S.Shrestha-4
      Hi, I am trying to simulate a two phase flow boiling of r134-a in 2d rectangular mesh. My calculation settings for transient are below. I keep seeing that the continuity residuals are not reaching the set convergence criteria of 1e-03. A mass imbalance as below is given:
                        Mass Flow Rate               [kg/s]
                                 inlet              0.17317
                                outlet          -0.24588628
                                   Net         -0.072716281
      Is the solution still correct and can I go ahead with running the calculation. How to know if the convergence is correct?
      You need to have a very careful look at the flow, flux balance and mesh. You may need to refine the mesh where you're seeing the steep phase gradients and reduce the time step.
  • The topic ‘Convergence of continuity residual at each time step’ is closed to new replies.
