convergence issue in the mechanical side of a FSI problem
    • azing
      I am simulating the behavior of a building in two perpendicular directions through nonlinear springs that are attached to a rigid box (please see the attached figure). The box is located on a spherical joint.
      I intend to couple this model with Ansys Fluent later on to take into account FSI using system coupling capability in workbench. That is why I chose flexible behavior for the box (since rigid surfaces were not accepted as valid options for FSI). However, in order to get rigid behavior, I increased the modulus of elasticity of the flexible body.
      I am now not able to get convergence in Transient structural and I think it is because of the rigid motion of the box since I get the warning "not enough constraints ... to prevent rigid body motion".
      I don't understand why it is not converging since I don't have a problem in the modal and static analyses. I would appreciate it if any one can help me with this.
      Thanks,
      Azin
Viewing 0 reply threads
  • The topic ‘convergence issue in the mechanical side of a FSI problem’ is closed to new replies.
