TAGGED: ansys-fluent, convergence, fluent, transient, transient-analysis
February 9, 2021 at 2:17 pm
rads
SubscriberI have been trying to perform a PCM melting simulation in FLUENT, but am facing convergence issue. There is normal melting at start of simulation, but then there is a very sudden drop in temperature after which the system becomes completely unstable and goes back up to a very high temperature in the next timestep.
Mesh Quality:
Minimum Orthogonal Quality = 3.52907e-01 cell 323206 on zone 9 (ID: 406547 on partition: 0) at location (-1.57583e-02 2.41255e-03 1.67722e-02)
(To improve Orthogonal quality , use "Inverse Orthogonal Quality" in Fluent Meshing,
where Inverse Orthogonal Quality = 1 - Orthogonal Quality)
Maximum Aspect Ratio = 7.91960e+00 cell 193565 on zone 9 (ID: 276906 on partition: 0) at location (-1.39062e-02 2.66648e-03 1.59572e-02)
Domain Extents:
x-coordinate: min (m) = -2.000000e-02, max (m) = 2.000000e-02
y-coordinate: min (m) = -6.123234e-19, max (m) = 3.664102e-02
z-coordinate: min (m) = 0.000000e+00, max (m) = 5.000000e-01
Volume statistics:
minimum volume (m3): 1.368996e-11
maximum volume (m3): 5.474989e-10
total volume (m3): 3.864102e-04
Face area statistics:
minimum face area (m2): 3.245439e-08
maximum face area (m2): 1.006125e-06
Checking mesh...........................
Done.
February 9, 2021 at 3:22 pmRob
Forum ModeratorWhat changes in the simulation result to trigger the sudden temperature problem? nFebruary 9, 2021 at 3:29 pmrads
SubscriberNot sure. I had not made any changes in the model. this is during a continuous run. nFebruary 9, 2021 at 5:31 pmKarthik Remella
AdministratorPlease check your residuals at this point when you see this change in trend. If these residuals look good and very similar to the previous one, this point is telling you something about the physics you are attempting to model. nI'd strongly recommend that you inspect your simulation before and after this spike and you might get a clue as to what might be happening. nKarthiknFebruary 9, 2021 at 5:48 pmFebruary 9, 2021 at 6:04 pmAmine Ben Hadj Ali
Ansys EmployeeADD Information about pcm material and melting model.nFebruary 9, 2021 at 6:25 pmrads
SubscriberADD Information about pcm material and melting model./forum/discussion/comment/106177#Comment_106177
This is what I used as my PCM material propertiesn I am sorry but I am not sure what exactly you mean by melting model. I am new to this, could you please elaborate? nThanksnn
February 9, 2021 at 6:26 pmKarthik Remella
AdministratorYour model doesn't seem to be converging properly. Also, provide some screenshots of your convergence strategy - Time-step, solution schemes etc.nKarthiknFebruary 9, 2021 at 6:30 pmrads
SubscriberYour model doesn't seem to be converging properly. Also, provide some screenshots of your convergence strategy - Time-step, solution schemes etc.Karthik/forum/discussion/comment/106180#Comment_106180
n
February 9, 2021 at 7:18 pmAmine Ben Hadj Ali
Ansys EmployeeDefinitely high time step. Add material panel from Fluent, I want to check something.nFebruary 9, 2021 at 7:27 pmrads
SubscriberDefinitely high time step. Add material panel from Fluent, I want to check something./forum/discussion/comment/106191#Comment_106191
Here you go.nnWhat would be the recommended Time step?.Thanks n
February 9, 2021 at 10:29 pmKarthik Remella
AdministratorPlease estimate the time-step to make sure that the CFL number is ~1. It depends on the velocity and smallest grid scales.nCFL = del_t * V / del_x ~ 1nI agree with 5 s is too large a time-step.nKarthiknFebruary 10, 2021 at 10:31 amrads
SubscriberChanged the settings to adaptive time control with CFL -based. It worked. nThanks everyone for your help!-
December 21, 2022 at 6:03 pm
GUNA AG
SubscriberPlease tell me how you choose adaptive time control
February 10, 2021 at 12:39 pmKarthik Remella
AdministratorExcellent!nFebruary 10, 2021 at 1:58 pmAmine Ben Hadj Ali
Ansys EmployeeGreat!nApril 3, 2023 at 1:33 pmRaiyaan S
SubscriberI am trying to solve similar kind of problem... can you kindly send screenshot of boundary conditions.Viewing 15 reply threads- The topic ‘Convergence issue in PCM simulation Fluent.’ is closed to new replies.
Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
4062
1487
