November 29, 2024 at 12:45 am
aagalvez
SubscriberI am having issues in the convergence of my residuals. My criterion at x,y, z vel, k and e are set to 1e-5 and continuity set to 1e-4. K and continuity cant even reach 1e-5 and 1e-4 respectively. May I know if the transition of my meshing from one domain to another is good? If not, what are your suggestions? I am using non-conformal meshing. I attached the figure of my meshing.
November 29, 2024 at 9:31 am
Forum ModeratorIt's bad. You're aiming for a similar size cell on both sides of the interface. It's possibly OK purple-pink in the inflation region, but that's about it. There's also no where near enough resolution to pick up the wake region.Â
November 29, 2024 at 2:38 pm
aagalvez
SubscriberThank you for your reply Rob. My meshing is non-conformal. Do you mean I will apply share topology?Â
November 29, 2024 at 2:55 pm
Forum ModeratorNo, you need to manually set some sizing to ensure the stator regions have a similar cell size as the rotor.Â
November 30, 2024 at 1:49 am
aagalvez
SubscriberÂ
Thank you rob. Ill try to change the size cells. Do you mean like changing the facesize elements in the interfaces?
December 3, 2024 at 1:41 pm
Forum ModeratorYes. You need to have a similar cell size on both sides of the interface.Â
December 4, 2024 at 2:20 am
aagalvez
SubscriberThank you sir for your suggestion
5824
