April 28, 2020 at 10:38 am
Muhammedcreed1
SubscriberHi everyone,
I am trying to simulate a pipe bending process but i get a convergence error. I turned on the auto time steeping and also refined the mesh but no luck. Here are some pictures of the errors. Also i get a partial solution. I also have the student version and i am still learning so excuse me if i do something wrong.
April 29, 2020 at 8:56 pm
Wenlong
Ansys EmployeeHi Muhammedcreed1,
You have a solver pivot warning message, which usually means the model is not properly constrained. Can you check your "joints" and make sure all the parts are properly constrained. Maybe you can add several images here.Â
This is not relevant but using hex mesh on the pipe will generally give a more accurate result.
Wenlong
April 30, 2020 at 3:52 pm
Muhammedcreed1
SubscriberHi Wenlong,
Thanks for your reply,
I have made a new model similar to the one posted above and have managed to remove the solver pivot warning. I have also used the hex dominant method to make a finer mesh. Here is what i got in the pictures below. I still got a partial solution.
The force convergence graph also shows some substeps are converging. ( Note: this is not the full graph)
April 30, 2020 at 8:59 pm
Wenlong
Ansys EmployeeHi,
Thanks for the detailed reply. So the Newton-Raphson residual shows the problematic region is where the pipe contacts the big roller. This is just a wild guess here, but can you please try varying the normal stiffness factor in contact settings (maybe try 0.1 in the first run and 10 in the second run)?
Wenlong
April 30, 2020 at 11:31 pm
Muhammedcreed1
- The topic ‘convergence error of Nonlinear analysis of pipe bending’ is closed to new replies.
3597
1208
1092
1068
952
