July 25, 2020 at 9:37 am
July 27, 2020 at 7:07 am
Keyur Kanade
Ansys EmployeeAre you using transient?
Did you refine mesh enough to resolve the flow?
Make sure you have sufficient no. of cells in region of interest.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
- The topic ‘Convergence behaviour’ is closed to new replies.
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
- Two-way FSI simulation
- Question about generating Porous Jumps
- The result in FLUENT differs from CFD Post
1494
1386
1209
