TAGGED: cfd-post, fluent, fluent-post-processing, shear-stress, turbulent-flow
July 28, 2021 at 11:16 am
ag1991
SubscriberHi,
I am conducting a CFD RANS simulation where SST k-w turbulence model is employed. Is there any way to obtain contours of turbulent shear stresses? (even if it required the use of custom variables). These are not wall shear stresses, as I am keen on knowing the values on a set of specific plane surfaces.
Thanks in advance
PS: Be it on Fluent or in CFD-Post.
July 29, 2021 at 11:04 pmSurya Deb
Ansys EmployeeHello,
You can create a CFF with Strain Rate Magnitude [under Derivatives] and Turbulent Viscosity [under Turbulence].
Regards SD
July 30, 2021 at 10:30 amag1991
SubscriberHi sdeb, thank you very much for your answer, it was quite useful.
Viewing 2 reply threads- The topic ‘Contours of Turbulent Shear Stresses’ is closed to new replies.
5694
1891
1419
