TAGGED: apdl, contour-result, mechanical-apdl, stresses
December 20, 2021 at 5:26 pm
Mdiogocarvalho
SubscriberHi Everyone ,
I've been trying to use the /Contour Funtion to modify the contour plots I'm using. The idea is to plot only regions of my model where the stress is over a certain value . Is it possible to obtain such with the following command?
/CONTOUR,Â
WN,ÂNCONT,ÂVMIN,ÂVINC,ÂVMAXFor me it is important to define the VMIN , while the VINC and VMAX would be automatically calculated.
Thank you!
December 21, 2021 at 7:56 amSaumadeep Choudhury
Forum ModeratorHi @Mdiogocarvalho
Please refer to this link to get an idea of how to use Contour Function - /CONTOUR (ansys.com)
Regards, Saumadeep
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
December 21, 2021 at 8:13 amMdiogocarvalho
Thank you for your reply. Perhaps I should have reframed my question better:
Is it possible to have a user defined minimum , while having ansys calculating the maximum ( or vice versa)? This is not clear in the command definition, nor it has worked for me as I've been trying multiple times. At least for me it does not provide the limits I want. Is there a better alternative for this command?
Regards M├Ãrio
December 23, 2021 at 8:23 amVigneswaran Sridharan
Ansys EmployeeHi I checked on the command /CONTOUR (ansys.com), it works fine for me.
You can set the user-defined minimum value to 'VMIN' and max value to 'VMAX' to have the contour display to plot only regions of the model where the stress is over a certain value.
For example:
/POST1
SET, LAST
PLNSOL, S,Y, 0,1.0
/CONTOUR,,,100,,168
/REPLOT
This will plot the regions of the model where stress is between 100MPa and SMax. Note: My SMin=66.87Mpa.
Also, check on /COLOR (ansys.com) to modify banded contour colors.
Vigneswaran
Ansys Help
December 23, 2021 at 8:43 amMdiogocarvalho
Thank you for the reply! But in your case you defined both VMIN and VMAX. What I wanted was to leave the VMAX non defined , so I would only plot values above VMIN (while VMAX could change depending on the changes I make to the model). I think /Contour does not allow this, and perhaps I should define an interval to fit all possible variations in the analysis.
Thank you for the help!
Regards M├Ãrio
Viewing 4 reply threads- The topic ‘/Contour Function on Mechanical APDL’ is closed to new replies.
5824
