July 19, 2022 at 5:37 pm
Dubey92
SubscriberI am modelling Selective Laser Melting(SLM) in FlUENT using Explicit VOF. One phase is inert gas and the other is metal. I am applying Laser over the particle bed using a UDF. The solution starts and initially the convergence is very good. Then after some time steps, the continuity equation does not converge. Other equations converge. There is a oscillatory behaviour in the convergence of the equations. I have attached the image. Any help is much appreciated. I am using Explicit VOF with a Courant number 0.05 and the Global courant number is 0.1.
July 19, 2022 at 10:49 pm
RK
Ansys EmployeeHello,Â
Have you setup any monitors to see how the simulation is behaving? If not, I would suggest you to do so. You might also want to reduce the URFs to check if it would help. Check this link for solution strategies : 22.8. Solution Strategies for Multiphase Modeling (ansys.com)
July 20, 2022 at 5:27 am
Dubey92
SubscriberHello Rahul, thanks for your reply. I have not set up any monitors. I am new to this type of modelling. Can you please suggest some parameters which I can monitor? As for the URFs, I am using a URF of 0.6 for the momentum, 1 for density and 1 for body forces. I am attaching the figure which shows my model domain. The laser starts but it does not move forward as the continuity equation is not converging smoothly.
July 20, 2022 at 12:48 pm
Forum ModeratorCheck the local velocity. If the material has/is melting are you still respecting the local courant number? I'd also review the temperature field, why have you got randomly scattered facets at 2500K or so in the image?
July 20, 2022 at 1:26 pm
Dubey92
SubscriberRob, thanks for your suggestion. I am using a very small courant number for VoF(0.05). I am applying the Laser source on on the top interfacial cells between the gas and the metal. The temperature values are in the range what I expect. The issue is only with the convergence of continuity equation. I haven't checked the velocity values yet but will do.
August 5, 2023 at 10:48 pm
CKS
SubscriberHi Dubey92, I'm having the same issue as well. I managed to run 75% of the VOF simulation for the SLM process and suddenly the continuity doesnt converge.
Can you drop me an email (chun.sit@monash.edu) where I can show you some of my (incomplete) simulation results?
August 9, 2023 at 5:38 am
Dubey92
SubscriberÂ
Hi. You can mail me at Edited as requested Rob
August 9, 2023 at 8:28 am
Forum ModeratorI would usually delete email addresses, and will do so once you (Dubey) let me know you're in contact. In return, please post any resolution/notes that will help others with this application.Â
August 9, 2023 at 11:40 pm
CKS
SubscriberI have got Dubey's response. Yo may proceed to deleting the emails. Thanks and I may open a new ticket for my specific issues later.
August 8, 2023 at 9:03 am
Forum ModeratorWhile we're waiting for Dudley, check the flow field just before the model diverges. Is anything changing or about to change? Ie is the model flow timescale about to shorten for some reason?
- The topic ‘Continuity Equation Convergence issue in Selective Laser Melting using VoF’ is closed to new replies.
5649
1885
1404
1303
