July 13, 2020 at 12:13 pm
July 13, 2020 at 3:37 pm
SaiD
Ansys EmployeeHi,
You either need to create a Contact OR a Joint between the two. There is no need to create both. A Fixed joint seems like a good option if there is no relative movement between the I-beam and plate. A "No Separation" contact means that there is no separation between the two in the normal direction, but there can be relative sliding. What behavior do you want? If there is absolutely no relative motion between the two, a Bonded contact may be used.
What do you mean by "incorrect results"? What was the expected result and what did you get from the current analysis? Please elaborate a bit on the boundary conditions and the relative motion between the I-beam and the plate.
Sai
July 13, 2020 at 4:06 pm
Wenlong
Ansys EmployeeBetween contact-no-separation and bonded joint you only need one of them. Either of them should work in your case.
Wenlong
- The topic ‘Contacts – Question’ is closed to new replies.
4823
1587
1386
1242
