November 25, 2024 at 12:06 am
cma6301
SubscriberHello,
I want to extract particles contact properties since there is no script for that, I modify the script for export particle information inorder to export the contact properties. When I used getCollectContactsData(time_step):, to export the contact particle at each time step I get an argument error. But without the argument "time_step" the script export comtact data only data it export just a single value at each output time. Where as I want the contact properties of each time_step at every output frquency. The image below is the data I get without the argument "time_step".
Is there a way to get the script produce more than one argument?
Best regards,
Ayuk
November 26, 2024 at 10:23 am
Forum ModeratorMaybe include which solver you're using?Â
