May 10, 2024 at 11:35 am
Lexi Clucas
Subscriber -
May 11, 2024 at 12:40 pm
peteroznewman
SubscriberThe solver sometimes issues a rigid body warning on models where there is nothing wrong, the model solves and the results look good.
You got the rigid body warning. Did the model solve and did you look at the results? If the deformation plot looks like the contacts are working properly and the model as a whole is deforming properly, you can ignore the rigid body warning.
Another suggestion is in Workbench, drag and drop a Modal analysis on the Static Structural Model cell then in Mechanical in the Modal section of the Outline add a Fixed support on one face. Change the Analysis settings to request 10 modes. When you solve Modal, what is the frequency of the first mode? If that is a tiny number or zero, then one or more of the bodies is not connected and you can see by animation of the modes which part is unconnected.
- The topic ‘Contacts have zero gaps but still far open’ is closed to new replies.
