Contact tools does not get solved.
    • Durgesh Pandey
      In my wheel and shaft connection, I can not get the solution for contact tools. I have no error message why it might be. How could I solve the issue and get the results?
      (Let me know if further information is needed)
    • Sampat Kumar
      Hi Durgesh,
      Is this issue related to this model specific only or it’s happening with every model?
      Sampat
    • Durgesh Pandey
      It is happening to every model. I tried modeling a simple model and work on it. same issue
    • Sampat Kumar
      Hi
      Which Ansys version are you using?
      Sampat
    • Durgesh Pandey
      Workbench 2021 R1
    • Sampat Kumar
      Hi
      Have you installed any other, newer, or older version of Ansys on the same system and tested it? Is this issue related to the other version as well?
      Sampat
    • Sampat Kumar
      Have you tried to clear %appdata% and %temp% data in your system for this specific version?
      Use the following link to get help of clearing %appdata% and similarly clear %temp% data.
      https://featips.com/2022/02/11/when-all-else-fails-reset-appdata/
      Sampat
    • Durgesh Pandey
      Clearing app data did not help either :(
    • DEVICHANDAN.PADALA
      Hi, Durgesh Pandey
      I have observed this kind of issue before and i have noticed that whenever there is Problem with licensing the contact tool won't work, try checking the license once, or it might be Flexnet issue.
    • Sampat Kumar
      Hi Durgesh,
      Are you able to run your model and able to retrieve any results without generating the contact information in the contact tool?
      Sampat
    • Durgesh Pandey
      yes, I can get results without contact information but I can not control my interference contact without this information. So, i run program control for the pinball radius/region
    • Sampat Kumar
      Can you uncheck the distributed solve just for the contact and try to generate the contact tool information?
      Sampat
    • mrife
      Hi Durgesh Pandey
      Can you please right-click the Connections object and Insert a 'Solution Information'.  Then generate the initial contact and post the top of the resulting solution information.
      Also at the very top of WB Mechanical the license checked out should be given in brackets [].  What license was checked out?
      Mike
    • Durgesh Pandey
      Here is the solution information
      I am not sure about the license part. Are you talking about this?
    • mrife
      Hi Durgesh Pandey
      Regarding the WB Mechanical license in the [] – here is a screenshot that is (hopefully) clearer than my description:
      There is a service pack for the Structures 2021 R1 installation that fixes this licensing issue with the contact tool.  Since you seem to be a “regular customer” by the fact that you show a Mechanical Premium license available please have your system administrator download and install that service pack.
      Mike
Viewing 14 reply threads
  • The topic ‘Contact tools does not get solved.’ is closed to new replies.
