September 12, 2025 at 11:06 am
tinsaegbehaga
SubscriberHi,
I’m running simulation on Static Structural and seeing unrealistic deformation. The model is a stack of thin-film layers with different thicknesses and material properties. I ran a thermal analysis on Thermal–Electric tool and imported those results into Static Structural to study thermal-expansion mismatch effects.
However, I’m getting a warning: “The maximum contact stiffness is too big.” and also the result I saw is not realistic. I tried adjusting the normal stiffness control from Programmable to Factor in specific contacts and tested different values, but the issue still persists.
Could anyone help me on this?
Thanks
September 12, 2025 at 11:49 am
Subhash Tadala
Ansys EmployeeThis warning occurs when normal contact stiffness (FKN) is higher than 10^16.
Can you check if changing the unit system is helping to avoid this issue ? -
September 19, 2025 at 9:13 am
tinsaegbehaga
SubscriberThank you for the response. I have created the geometry again in meters when I do the thermal anlysis in thermal electric and use Pa when I insert youngs modulus values in my stress analysis in static structural. But the issue still persists. Is there any other thing I need to check?
