TAGGED: ansys-contact, Contact Method, contact-behavior
April 25, 2025 at 10:51 am
mohammad.asgharitalab-arezoomand
SubscriberHello There,Â
I have a small thin surface and a solid body under it. I push the foil down with pressure, so that they are in Contact (Frictionless with Augmented lagrange formulation).Â
then I want to delete the pressure, but also change the contact type, sop that after deletion of pressure they remain in contact. and then I need to analyze the contact pressure and force reaction.
I have tried No Separation and rough contact for the second step , but it does not converge at all.
Have someone maybe done sth like this before? please write me some tips, if you know.
Thank you in advance -
April 25, 2025 at 5:17 pm
April 25, 2025 at 6:50 pm
peteroznewman
SubscriberMy reply in this discussion may be relevant.
https://innovationspace.ansys.com/forum/forums/topic/contact-question-gluing-deformed-parts/
2999
970
857
761
599
