October 29, 2021 at 7:22 am
sombodyfromtheworld
Subscriberhello
Why I cannot see the contact information for my contacts?
October 29, 2021 at 8:02 amSurya Prakash
The thunderbolt sign near the "initial information" represents that the cell is ready to be solved, and it is not solved yet. Once you solve it, the sign changes to a green checkmark, indicating that the results are available.
To know more information on that, you can refer to the help document - Contact Tool Initial Information (ansys.com)
Regards Surya Prakash
October 29, 2021 at 8:12 amsombodyfromtheworld
Subscriberthe thing is that the thunderbolt sign doesn't turn green after i solve/generate initial contact results
and no information is available for contacts
October 29, 2021 at 9:46 amSurya Prakash
There are some limitations and restrictions, on not following these might lead to these errors. You can refer to the document for the guidelines - Limitations and Restrictions for Model Assembly (ansys.com) and make sure you are following them.
Regards.
Surya
Viewing 3 reply threads- The topic ‘contact status unavailable’ is closed to new replies.
5989
1307
