February 16, 2022 at 8:10 pm
fea11
SubscriberContact status has experienced an abrupt change. Check results carefully for possible contact separation. I checked my results after Solution, but couldn't find any contact separation. I also did a contact check before and after the solution, but there is no change. How serious should I take these warnings? Are these stress results reliable?
February 17, 2022 at 7:19 amVinayak Vipradas
The "contact status has experienced an abrupt change" is a warning message, which tells the user that the contact status is rapidly changing between "closed" and "far open" without going through the status "near open". A more stable solution could be reached if the contact is changed between "closed" and "far open" via "near open". This warning message usually does not cause a problem when solving a model. But it could indicate that the model could have "open" contacts or rigid body motion. Could you please check your model to make sure the model has no rigid body motion and all contacts in the model are closed? The initial contact status can be found by inserting a contact tool and then generating initial contact information under Connections.
Vinayak
How to access the ANSYS Online Help ÔÇö Ansys Learning Forum
Rules & Guidelines ÔÇö Ansys Learning Forum
Viewing 1 reply thread- The topic ‘Contact status has experienced an abrupt change. How serious is this warning?’ is closed to new replies.
4678
1565
1386
1241
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
