January 25, 2021 at 10:42 am
RavndraGouda
SubscriberHello All,nI am doing the modal analysis for a RCC structure using Ansys workbench.nCould you please help us for contacts modelling between the rebars (horizontal and vertical) and rebar reinforcement in concrete block using Ansys workbench.nappreciate your help on this.n n -
January 29, 2021 at 12:51 pm
Ashish Khemka
Forum ModeratornnPlease refer to the link below:nnnRegards,nAshish Khemkan -
January 29, 2021 at 1:18 pm
Erik Kostson
Ansys EmployeeWe have a much better workflow now (in 2020 release and onwards) for the rebars using the reinf264 elements - you just add your steel rebars as line bodies and then use a reinforcement type (see yellow highlight in the image below) in mechanical instead of beam and they will be automatically embedded in the concrete. So we do not need any contacts or anything. Just use reinforcement type.nnSee here for more info:/forum/discussion/12308/error-with-reinf264-elementsn
January 29, 2021 at 1:28 pm
Erik Kostson
Ansys Employeen
- The topic ‘Contact modeling for Steel rebars in Concrete using Ansys workbench’ is closed to new replies.
Ansys Innovation Space
970
857
755
599
