November 29, 2019 at 10:00 am
Autonewbie
SubscriberHi,
I am running a random vibration based on modal results for an assembly. Is there other method that I can assess the non-linear contact stress in Random Vibration as I understand it is linear contact in modal and random vibration?
November 29, 2019 at 1:51 pm
peteroznewman
SubscriberYou must use Full Transient Structural (not using Modal as a Pre-analysis) in order to see nonlinear contact such as Frictional or Frictionless contact working as you want, by opening and closing and sliding around. Note that No Separation is a linear contact so you can get the sliding around part working in Random Vibration.
However, the input to Full Transient is a load-time history, while the input to Random Vibration is a PSD load spectrum, so you have to have or synthesize a load-time history to use Full Transient.
November 29, 2019 at 2:00 pm
Autonewbie
Subscriber I also interested of Random Vibration but Random Vibration is linear analysis, right?
November 29, 2019 at 2:06 pm
peteroznewman
SubscriberYes, Random Vibration is linear.
November 29, 2019 at 2:13 pm
Autonewbie
SubscriberWhat happened was the area of interest has been shifted to the area of fixation (bolt hole). If bolt is modeled in with contact but non-linear is not supported ... what would be the best solution to account for the nonlinear contact in random vibration?
November 29, 2019 at 7:10 pm
peteroznewman
SubscriberPlease explain using images, labels and pointers.
November 30, 2019 at 4:07 pm
Autonewbie
SubscriberBasically, I would like to know the nonlinear contact stress under Random Vibration...
December 2, 2019 at 12:48 am
peteroznewman
SubscriberA nonlinear contact is Frictional, Frictionless or Rough contact. To use that in a simulation, you must use Transient Structural.
Transient Structural is a time-history simulation where you can use nonlinear contact.
Random Vibration is a frequency-based analysis which requires Linear Contact.
You can synthesize a time-history load for use in a Transient Structural model from a Random Vibration PSD specification. I can help you with that if you want.
December 2, 2019 at 1:53 am
Autonewbie
SubscriberI would be love to hear that. Thanks in advanced!Â
What should I provide you? PSD profile and a model?
December 2, 2019 at 4:11 am
peteroznewman
SubscriberI only need the the PSD profile to synthesize a time history. You can reply with that as lines of text in the post. Attach the model .wbpz file for my interest.
You should do the MSUP Random Vibration model first anyway to see how many orders of magnitude the solution time is compared with the Transient Structural. We're talking minutes vs. tens of hours, and that is assuming you don't run out of disk space during the solution.
December 2, 2019 at 5:42 am
Autonewbie
SubscriberI share the PSD below. For the model, I need times to prepare a similar for you.
I already have the MSUP random vibration but that leads to another concern as many modes are required if meeting the participation factor or maximum frequency of the PSD profile. I ran the model up to lower frequency (800 Hz if refer to the PSD profile below) as damage is higher in lower frequency. Correct me if I am not right. Thanks!
December 2, 2019 at 1:35 pm
peteroznewman
SubscriberI have matlab and use a GUI package called vibrationdata that has a script to synthesize an acceleration time history from white noise to meet a PSD specification. The script requires input in terms of G^2/Hz, but the package also includes a unit conversion.
The sampling of a time history should have 20 samples/cycle, so to properly reproduce a 1500 Hz signal, the sampling would ideally be at 30 kHz. Attached is a signal sampled at 26 kHz. It is 2.5 seconds long and has 65,536 data points.
Here is how well it meets the PSD specification
December 2, 2019 at 2:02 pm
Autonewbie
SubscriberHi Peter,Â
It is so cool! I guess next step is to use this time domain profile in running transient simulation, is that right?
December 2, 2019 at 2:55 pm
peteroznewman
SubscriberYes, insert a Transient Structural model into Workbench and open Mechanical. Copy all the data in the text file and paste it into an Acceleration load when the units are set to meters and seconds.
December 10, 2019 at 1:32 pm
Autonewbie
SubscriberHi Peter,
Is it what you have done is converting the PSD input to displacement over time at every frequency for transient analysis? How do we calculate that?
December 10, 2019 at 1:48 pm
peteroznewman
SubscriberI have matlab and use a GUI package called vibrationdata that has a script to synthesize an acceleration time history from white noise to meet a PSD specification in terms of G^2/Hz.
The GUI package with that script is free and open source. Here is a link to download the package. You can look at all the calls to various functions and see how it is done.
May 13, 2020 at 12:00 pm
MTBXC
Subscriber Hi, Peter,
Have you met with similar software? E.g. to scilab, or other free software?
January 20, 2021 at 11:36 am
GP_FEM_CFD
SubscriberHi Peter! I have the same situation like @Autonewbie. The topic here is really useful but that MATLAB tool has too many opportunities and it is not that well explained how exactly can be transform PSD profile to acceleration signal which I want to use later in Transient Structural. Coul you give me somehow tips how to use it  Thanks in advance!n
- The topic ‘Contact in Random Vibration’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3862
1414
1220
1118
1015
