TAGGED: -transient-structural, #contact, apdl, apdl-commands, macros/scripting, mapdl
March 28, 2024 at 2:56 pm
oglawal2
SubscriberHi, I converted a workbench model to apdl by writing the input file. Now I'm trying to write the script to get the same results I obtained in workbench.
First I will like to obtain impact force from my simulation. I understand from previous response I get that I can do this by selecting contact elements, then associated nodes and then get nodal force. Question I have regarding this is will I do this under /post1 or /post26, and also I have multiple contact regions in my model, how do I specify the exact one I want (it is a frictionless surface to solid contact).
Second issue is I have two load steps. In workbench I can specify how to store the output for each load step (e.g. at equally spaced points). How can I do the same in apdl scripting?
Thanks.
April 1, 2024 at 4:41 pm
Avnish Pandey
Ansys EmployeeHi Bolaji,
Contact forces can be determined under both /POST1, the general post processor and /POST26, time-history post processor.
CNCHECK command will give you the information about the existing contact/target pairs. You need to know the REAL and TYPE attributes of the contact/target elements.
You can use LSWRITE command to store data for each load step. You can check below forum discussions for more information on scripting for different load steps.
/forum/forums/topic/creating-multiple-static-load-steps-in-apdl-loading-unloading-simulation/
/forum/forums/topic/how-to-store-fsum-command-for-each-load-step-into-an-excel-file/
- The topic ‘Contact force from transient structural apdl’ is closed to new replies.
5824
