January 23, 2024 at 10:18 am
user deleted
SubscriberHello Everyone,
I'm currently learning the SPH method.
I'm using an implicit solver.
I'm trying to solve the problem of contact of 5 bodies, one of which is SF
Contacts type: nodes-surface
Unfortunately, the contacts do not work; the bodies penetrate each other.
I would be grateful for advice/hints.Â
Thanks in advance
Best Valery
January 26, 2024 at 12:20 am
Jim Day
Ansys EmployeeAre you running implicit static or implicit dynamic?  What value have you assigned FORM in *CONTROL_SPH?  Which *MAT have you assigned the particles and does that material represent a solid material or a fluid?  Show me your *CONTROL_SPH data and your *CONTACT data.
January 27, 2024 at 4:14 pm
user deleted
Subscriber -
January 27, 2024 at 4:37 pm
January 29, 2024 at 4:30 pm
Jim Day
Ansys EmployeeSince you're using elastic material in this test, try FORM=0 in *CONTROL_SPH.  Set ITHK=1 in *CONTROL_SPH as well so that the radius of the particles are considered in the contact treatment.  Include *DATABASE_RCFORC will write histories of contact forces to rcforc; plot these forces to see if contact forces are being produced.  Set SOFT=1 in the *CONTACT input.
January 29, 2024 at 7:28 pm
user deleted
Subscriberthanks for the advice and kindness
but unfortunately there is no solution
*** Error 60038 (IMP+38)
   *        -  FATAL ERROR  -             *
   *  Type 3 data conflict encountered in while       *
   *   assembling elemental matrices.           *
   *  Invalid internal node number             *
   *   internal node number =   2059           *
   *   number of nodes    =   1226           *
   *  Please report this message to LST.          *
January 29, 2024 at 8:53 pm
Jim Day
Ansys EmployeeThis may be an incompatibility between SPH and implicit.  In my own implicit test case, the SPH nodes never move. As an experiment, try using the explicit solver and report what happens.
January 30, 2024 at 9:49 am
user deleted
SubscriberSPH and explicit solver work successfully.
- The topic ‘Contact FEM/SPH (implicit solver)’ is closed to new replies.
5779
