February 22, 2022 at 10:47 am
mertnarinn
SubscriberFebruary 22, 2022 at 11:27 amjonsoln
SubscriberHi!
If you have a gap between the ball and plate the contact might not behave as expected. Try doing a initial contact status check (Connections -> Insert Contact Tool -> Generate Initial Contact Results) to see what the initial gap and penetration is.
February 22, 2022 at 11:30 ammertnarinn
SubscriberFirst of all, thank you for your advice. When I do what you say, I get the error "You have a contact tool with invalid contact selections or result requests". How can I solve it?
February 22, 2022 at 1:44 pmFebruary 23, 2022 at 10:48 amFebruary 24, 2022 at 6:20 amjonsoln
SubscriberWhen the contact is open or far open, no contact elements are created and the ball will penetrate through the plate. You can try setting the pinball radius manually to a larger number. I don't know why the contact is far open, since the listed pinball is already greater than the gap and penetration.
The pinball determines how large the initial distance between the contact and target surfaces needs to be for the solver to ignore contact at that point.
Viewing 5 reply threads- The topic ‘Contact Definitions’ is closed to new replies.
