July 6, 2023 at 3:41 pm
Ben_Ben
SubscriberI am inflating a bag like structure with a pressure. As seen here: bag before and after inflation
It needs to contact with several other bodies. However, it fails to contact with some of the bodies.Â
Here is an example of a successful contact: Before and AfterHere is an example of an unsuccessful contact: before, during and afterÂ
Both of the bodies are marked as targets with the inflated bag as the contact. The contact is a simple frictional contact. I have tried frictionless but this didn't help.Â
Here are my contact settings:
Thanks,ÂBen
July 7, 2023 at 11:48 am
Ram Gopisetti
Ansys EmployeeHi, i am not aware if you use any single surface airbag contact in your model, if not use it,Â
increase the stiffness factors by using the lsdyna contact definition.Â
cheers, ramÂ
July 7, 2023 at 11:51 am
Ben_Ben
SubscriberHow do I find the lsdyna contact definition? I haven't used single surface airbag contact in this model.Â
I'm using Workbench LS-Dyna are these availble?Â-
July 7, 2023 at 12:02 pm
July 24, 2023 at 9:00 am
Ben_Ben
SubscriberI got the contact to work by using a soft constraint formulation. Not sure why, but it works now.
- The topic ‘Contact breaking down. With large penertrations.’ is closed to new replies.
5754
