January 10, 2019 at 6:15 pm
shisyphus
SubscriberIs there a tool to draw construction lines on DesignModeler?
January 10, 2019 at 7:45 pm
Sandeep Medikonda
Ansys EmployeeBased on the question, it is not clear what you want to do with the line. You can create sketches with lines or even create lines from sketches or points or existing geometry
You can use that for building additional geometry.
There are options to create lines to use as a reference for other sketches. Check sketching/draw toolbars.
Sandeep
Accessing online help -
January 10, 2019 at 8:04 pm
shisyphus
SubscriberSandeep, thanks for your reply. I am inquiring if there is an option for drawing construction lines on DesignModeler similar to most CAD software like Creo and Solidworks. For example, let's say I want to create a 2D rhombus grid before I start sketching or even a few concentric circle before I start sketching a gear (like in the photo below). Construction lines are reference lines that are not shown in the final sketch. I went over the link you have attached, but information on construction line and reference line is not there.
January 10, 2019 at 9:01 pm
Sandeep Medikonda
Ansys EmployeeYou can create all your circular lines in one sketch. Then in a different sketch draw your part. You can use the lines created in your first sketch and reference them to specify dimensions etc.
Sandeep
- The topic ‘Construction Line on DesignModeler’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3927
1414
1256
1118
1015
