TAGGED: ansys-workbench-mechancal, cfd-post, fluent, geometry, mesh-generation
January 15, 2021 at 4:06 pm
zypresse9
SubscriberHi all,
I'd like share to you that IÂ really don't understand why version 19.2 is extremely slow to construct geometry, for example:Â
it takes 8-10 minutes to draw a rectangular-by-3-points
       5-8 minutes to draw construction point at intersections
up to 10 minutes to trim a section
a very wide range of operations from simplest to most complex, take too much to study effectively, which is very frustrating.Â
It is for sure that I have no problem with connecting to university's licensing service and firewall is turned off.
Let me share my computer's technical specifications to you:
February 2, 2021 at 7:03 pmANSYS_MMadore
Forum ModeratorAre you able to test a newer release? Version 19.2 is no longer on support. I can recommend updating graphics drivers, and making sure you have installed ANSYS to a local disk and not a network drive, and your files you are working are also local.nViewing 1 reply thread- The topic ‘Constructing Geometry is extremely slow’ is closed to new replies.
4067
1487
