3D Design
3D Design
Constrain my sketch in SpaceClaim Engineer?
    • nselvara
      Sketches are not constrained in SpaceClaim because they are not intended to persist. Create a sketch to the correct dimensions, turn it into a surface, and then use the Pull tool to pull it into a solid. For best results, make edits to the resulting solid rather than editing the sketch.
    • nselvara
      How do I constrain my sketch in SpaceClaim Engineer?
    • KenGrimes1
      How can I draw a rectangle that is "X" in to the right of the origin?
      Draw the rectangle with the corner on the origin, then use the Move tool, select the rectangle, click on the X axis, and drag to the right. That will pop up a field where you can type in the value of "X" in inches.
    • FrankD
      Ken
      A handy shortcut when sketching, is to hold the Shift key while placing the mouse over some reference, prior to sketching the object (rectangle, line, or whatever) This will give you a convenient "initial-location X Y dimension set" to save you the step of later moving the sketched object. In this image, I am Just about to start sketching a rectangle, having shift-hovered over the origin point first:
      If the dimensions are skewed w.r.t. the reference point, place yourself a custom origin on the face prior to sketching and then the when you place the sketch plane (in the course of sketching) you can select an axis of the new origin to force the sketch XY axes to line up.
      F
Viewing 4 reply threads
  • The topic ‘Constrain my sketch in SpaceClaim Engineer?’ is closed to new replies.
