Console reporting for DPM
    • pnvk95
      Hello
      My simulation is running slowly because it is reporting the DPM data in the console after every time-step (part of report attached below). I want it to report every 1000 time-steps instead. How can I make sure the console doesn't report so often?
      CONSOLE OUTPUT SAMPLE
      Updating solution at time level N... done.
      Injecting 1000 particle parcels with mass 8.75e-14 at t = 0
        iter  continuity  x-velocity  y-velocity      energy     time/iter
      Advancing DPM injections ....
      number tracked = 1000, escaped = 0, aborted = 0, trapped = 0, evaporated = 0, incomplete = 0, incomplete_parallel = 0
      Flow time = 0.0005s, time step = 1
      99999 more time steps
      Flow time = 0.001s, time step = 2
      99998 more time steps
      Flow time = 0.0015s, time step = 3
      99997 more time steps
    • Keyur Kanade
      Are you using unsteady flow with unsteady particle tracking?
    • pnvk95
      Yes. Transient problem with unsteady particle tracking.
    • Keyur Kanade
      You may need to change dpm iteration interval.
  • The topic ‘Console reporting for DPM’ is closed to new replies.
