3D Design
3D Design
Connection timed out while reading data
    • paul pladet
      I am having trouble running Ansys spaceclaim on a computer. The server is running, the client pc can connect to the server with the Licensing Client Settings (although this takes a couple of seconds), but when starting SpaceClaim nothing happens. After a while i get the following error, see included image. We have tried to turn of the firwall and antivirus, but this still doesn't work.
      Any ideas on what i can do to solve this issue?
    • Naresh Patre
      Hello  Matt Madore
      Can you please assist with this license manager error?
    • Matt Madore
      Paesc Could you please check if you have the environment variable ANSYSLI_ELASTIC specified on your machine? If so, make sure it is set to a value of 0.
  • The topic ‘Connection timed out while reading data’ is closed to new replies.
