February 12, 2023 at 6:17 am
kiyarash rahbar
SubscriberGreetings,Â
I have developed a 2Way FSI in workbench using Transient structural, Fluent and System Coupling. After finishing the simulation, when I want to connect the solution cell of transient structural to results cell of fluent to investigate the results in 1 platform, I face with a forbidden sign that does not allow me to connect the solution cell of Transient structural to result cell of Fluent.Â
I greatly appreciate any comments
Regards
February 14, 2023 at 4:37 pm
Forum ModeratorI think you mean you want to look at post processing both lots of data in the same tool? I think you can do that with Ensight. You may need to export results from both tools to do this.Â
April 11, 2023 at 3:57 pm
hamideh.hayati
Subscriber@RobÂ
Does CFD-Post 2022 R2 support results from Transient Structural?Â
As an Ansys user and for my Ph.D. research I need confirmation from Ansys to make sure that the CFD-Post cell can no longer be connected to the Transient Structural Solution cell.Â
Thanks.Â
April 16, 2023 at 12:51 pm
kiyarash rahbar
SubscriberHello Rob.Â
Thanks. Yes I want to see results of FEA and CFD in one environment. Previous versions allowed the connection but apparently I cannot connect the transient structural to results cell. In my toolbox I have only Ensight (Forte) which it does not accept the connection of solution from neither transient structural nor from fluent or CFXÂ
Can you please assit with this matter and provide alternative solutionÂ
April 11, 2023 at 4:12 pm
Forum ModeratorIt looks like the functionality was removed in 2020R2 (judging from the standalone version Load Results panel).Â
April 18, 2023 at 10:17 am
Forum ModeratorEnsight should read the data, try in stand alone - I don't use Ensight so am not overly familiar with the exact workflow but do expect it'll work outside of Workbench.Â
- The topic ‘Connection issue in 2-Way FSI from Transient structural to Fluent’ is closed to new replies.
5754
