April 18, 2019 at 4:21 pm
yang
SubscriberHello!
In Workbench, is there anyway to model the connection between two elements as pinned connection (All moments are released, only tension or compression will be transferred between two elements), in other words, apply a pinned joint to two line bodies?
In default, the fixed connection (rigid connection) is applied.
Thanks!
April 18, 2019 at 4:37 pm
April 21, 2019 at 2:25 am
yang
SubscriberThanks! Appreciate it!
December 16, 2020 at 12:40 pm
Rameez_ul_Haq
SubscriberAssuming there are 3 separate line bodies in the example structure above, then how can we connect the columns to the horziontal line body, if we want to model the pinned connection? If we use end release, are we supposed to put the end release on only the horizontal line body's vertices, or we should also take into account the vertices of the columns as well (where the columns connect with the horizontal line body)?n -
December 16, 2020 at 1:24 pm
peteroznewman
SubscribernIf that was 3 separate line bodies, they would have to be using shared topology or have a Mesh Merge so that there was a single node at each corner that both beams were using. Without the End Release, that connection behaves like a welded connection. With End Release on the horizontal beam, that changes it to a pinned connection if the correct DOF is chosen.nOnly one of the two beams sharing a node needs an end release.n -
January 18, 2021 at 4:31 pm
dave
SubscriberThanks for your messages here, they helped me add an end release to my beam model. However, I note that the help file says I cannot apply a fixed boundary condition at the vertex with the end release. Is there a way I can fix the end of the beam with the end release, or would I need to extend the beam slightly so I have a separate point to apply the fixed boundary condition?nThanks for your help!n -
May 1, 2023 at 8:42 am
Arthur Lahousse
SubscriberHey guys as Peteroznewman said I have 3 lines body to connect and I want the 3 rotational DOF. I tried using shared topology then use end release but it doesn't seem to work. What is the solution to this problem please?
May 15, 2023 at 11:05 am
Aniket
Forum ModeratorPlease start a new thread with your question described in more details.
-Aniket
Viewing 6 reply threads
- The topic ‘Connection between two elements’ is closed to new replies.
1565
1386
1231
