October 15, 2019 at 2:33 am
ygauri
SubscriberHello everyone,
I am dealing with small model of vibracons ( rotachocks), as seen in attached image. Top part has external threads, while bottom part has internal threads. Now I want to perform analysis to see whether the threads can withstand the applied load or not. For that I am not sure about what type of connections should be use and how to apply that for threads, to make sure model is setup correctly.
Would be glad to get some advice as soon as possible.
Thank you for your time in advance.
October 15, 2019 at 4:39 am
Amine Ben Hadj Ali
Ansys EmployeeCan you insert the picture in the text? Which product are you using? -
October 18, 2019 at 3:08 pm
October 18, 2019 at 3:15 pm
Amine Ben Hadj Ali
Ansys EmployeeEdit: moving to structural -
October 18, 2019 at 3:27 pm
ygauri
SubscriberSo moving to structural means?
Sorry but I didn't understood well. Can you explain a bit in detail.
October 19, 2019 at 1:15 am
peteroznewman
SubscriberIt means you posted in the wrong category, and the discussion has been moved to the right category which is Structural Mechanics.
I replied in your other discussion. Please don't post the same question twice.
- The topic ‘Connection between the external and internal threads’ is closed to new replies.
4858
1587
1386
1242
