December 14, 2019 at 10:52 am
mehdiyahia1
SubscriberHello, I'm trying to do a simulation of conjugated heat transfer, the source is a 10*10 m2 cube located in a building of 50*50*20 m2, the building is in the atmosphere, my study is stable,realizable k-epsilon, when I checked the results I see that I do not have a semmytey around my cube, if there is an idea to improve the result, I would be very grateful.
December 14, 2019 at 10:54 am
December 14, 2019 at 10:55 am
December 16, 2019 at 11:44 am
Forum ModeratorWhy do you expect to see a symmetrical result?Â
December 16, 2019 at 12:18 pm
mehdiyahia1
SubscriberThank you for the reply Rwoolhou
I have unconvincing results when I use the symmetrical.Â
December 16, 2019 at 1:34 pm
Forum ModeratorHave a look at von Karman vortex street on Google: you may not have a symmetric flow.Â
December 16, 2019 at 1:59 pm
mehdiyahia1
SubscriberI think Von Karman vortex street, is only for the transient state regime
December 16, 2019 at 3:28 pm
Forum ModeratorYes and no. How good is your convergence?Â
December 16, 2019 at 4:14 pm
mehdiyahia1
SubscriberFor the convergence i have 0.1 for all except epsilon
December 16, 2019 at 4:25 pm
mehdiyahia1
SubscriberYes and no. what does that mean?
December 16, 2019 at 5:56 pm
Forum ModeratorIt means we can have a transient effect in the results when using the steady solver: it's usually identified by the way the residuals behave. Just curious, are you using the University licence?Â
December 16, 2019 at 6:00 pm
mehdiyahia1
SubscriberYes i used the university licence . Are you have some advice explains this phenomenon ?
December 16, 2019 at 6:11 pm
Forum ModeratorCan you post the residuals plot as it's easier to explain if I can see that. We're very limited on here due to export laws, so the more images the less trouble I can get into!Â
December 16, 2019 at 6:53 pm
December 17, 2019 at 10:25 am
Forum ModeratorPerfect, thanks.Â
I'd be more concerned with the temperature limits if you're not expecting 5000K in the domain, 1K may also be a concern. Open up Solution Controls > Limits and increase the turbulent viscosity ratio by about 4 orders of magnitude. Â
You've also not run anything like enough iterations to converge the solution: run another 500-1000 and let's see how it looks then.Â
December 17, 2019 at 12:05 pm
mehdiyahia1
SubscriberI already have a turbulent viscosity 1.
December 17, 2019 at 3:20 pm
Forum ModeratorNo, the viscosity ratio limit, not the boundary condition.Â
December 18, 2019 at 6:56 am
December 18, 2019 at 11:57 am
Forum ModeratorYes, that's showing a transient result: or more precisely that the solver is seeing many correct steady state results. Now compare the result from this solution with the plot you added earlier on.Â
I think there's a good solution on our (customer side) system and add the first 10-ish lines of the licence file here so I can find the local ANSYS contact.Â
January 12, 2020 at 5:37 pm
mehdiyahia1
SubscriberIt' s impossible to obtain the university license.
January 12, 2020 at 5:38 pm
mehdiyahia1
SubscriberI don't know if there's any other way you can help me.
January 13, 2020 at 10:22 am
Forum ModeratorVery simply, you have a solution that's not steady state. You can either use monitors to check the values of interest are fairly stable or switch to transient and use monitors to see how the values of interest change with time.Â
I can't advise on which approach is suitable as I don't know exactly what you're doing and what you need from the results.Â
January 13, 2020 at 11:13 am
mehdiyahia1
SubscriberI want to know the temperature distribution in my domain.
January 13, 2020 at 11:17 am
mehdiyahia1
SubscriberAnd the height that reaches the plume.
January 13, 2020 at 3:22 pm
Forum ModeratorAnd if you monitor those values do they fluctuate?
January 13, 2020 at 3:26 pm
mehdiyahia1
SubscriberExcuse me, but what you mean by monitor?
January 14, 2020 at 10:36 am
Forum ModeratorIn Fluent we can monitor (look through the list of commands in the tree - left side of the interface) data from within the solution. This is often done to check convergence (steady state calculations) or trends in transient. Since you're using 2019Rx click on "Help" and it'll take you to the documentation, from there you'll find the Fluent tutorials. Do the first few as one of those will have monitors as part of the set-up.Â
January 18, 2020 at 4:29 am
mehdiyahia1
SubscriberI have tried all your advice but I am still far from good results.
Here's my job. https://yadi.sk/d/OkivnVFPTUVtIw
Can you help me?
January 20, 2020 at 10:11 am
Forum ModeratorI'm not permitted to open/download attachments. Please post images, and explain why they're not what you're expecting.Â
January 29, 2020 at 10:06 am
mehdiyahia1
SubscriberNow, I use the method of symmetry.
In the first image, I have a discontinuity in the temperature values.
In the second image this discontinuity, nor that the temperature is 290, is physically inexplicable.
if I'm right, how can I explain it?Â
January 29, 2020 at 10:07 am
January 29, 2020 at 11:46 am
January 29, 2020 at 11:47 am
January 29, 2020 at 11:48 am
mehdiyahia1
SubscriberThe temperature in the cube is 2000 k
January 29, 2020 at 11:50 am
Forum ModeratorThe surface looks like you're picking up the mesh facets, have you checked you're fully resolving the flow?Â
January 29, 2020 at 11:54 am
mehdiyahia1
SubscriberHow can i do it?
January 29, 2020 at 11:57 am
mehdiyahia1
Subscriber"The surface looks like you're picking up the mesh facets" I don't understand what you mean?
January 29, 2020 at 2:30 pm
Forum ModeratorIf you look at the isosurface there are hard edges/features in the shape. This tends to imply the surface is following the mesh, or that the mesh isn't well refined.Â
To check the flow is resolved you either need to know what to look for or do a mesh dependency study. Note, using symmetry will prevent/alter eddy shedding so you may find you don't get as good agreement with the experiment.Â
January 29, 2020 at 3:05 pm
January 29, 2020 at 3:08 pm
mehdiyahia1
SubscriberAs I understand it, work with the symmetry it doesn't recommend in my case.
January 30, 2020 at 11:15 am
Forum ModeratorThat'll explain some/most of the problems. None of the zones are connected (you will have contacts which is OK, just not ideal given how simple the geometry is), and more critically the jump is cell size is awful. Have a look in the documentation tutorials and remesh the model. I suspect the results will be a lot better once you've fixed the mesh.Â
Note, having all good mesh metrics usually means the cells are OK. It does not mean the mesh (ie all the cells) is any good.Â
January 30, 2020 at 3:05 pm
mehdiyahia1
SubscriberYou're advising me to use ICEM for the mesh (my knowledge is very weak in the mesh).
January 30, 2020 at 3:36 pm
Forum ModeratorNo, I'd stick (unite) the volumes together and use Workbench or Fluent Meshing with the watertight geometry workflow.Â
https://www.youtube.com/watch?v=zFsa1Ezot8Y
ICEM CFD is very good for hex meshes, but not so straightforward to use.Â
January 31, 2020 at 3:26 pm
mehdiyahia1
SubscriberThank you very much sir for this helpful video,
I used Fluent Watertight geometry for the mesh, but I have a problem, I don't have my source in cell zone conditions, in return iin Workbench after DM and Mesh , this problem doesn't exist. -
January 31, 2020 at 3:27 pm
January 31, 2020 at 3:29 pm
January 31, 2020 at 4:05 pm
Forum ModeratorCheck the zone definitions in Fluent Meshing: they may need defining during the meshing process.Â
- The topic ‘Conjugated heat transfer’ is closed to new replies.
