September 26, 2024 at 3:30 am
1030869148
SubscriberHow can a conical spring's stiffness change when it undergoes significant deformation? I imported the built-in conical spring from SolidWorks into ANSYS Workbench and applied a certain deformation within the elastic range, but its stiffness remained constant, which is inconsistent with theory. What should I do?😖
September 26, 2024 at 6:42 am
ErKo
Ansys EmployeeÂ
Hi
We have had similar questions in the past in the forum – search the forum for these posts.
Also a paper shows when and how the spring becomes nonlinear and in which regime (depending on the type of conical spring).
The paper is called:
’Optimal design of conical springs'
Hope this helps.
All the best
Erik
1890
1419
1304
