July 3, 2019 at 2:09 pm
cryptonary
SubscriberHi all.
I am trying to simulate a conical-shaped pin (male) being pressed into a hexagonal cylinder female part, both made of copper. However, I don't understand the resulting contact pressure between the two parts. More specifically, there seems to be concentrations of contact pressure, but I expect it to be quite uniform, throughout.
I have attached images of the geometry, boundary conditions and results (contact pressure and equivalent stress).
Any help is appreciated. Thanks
July 3, 2019 at 3:13 pm
peteroznewman
Subscriber -
July 3, 2019 at 3:17 pm
peteroznewman
SubscriberI would also suggest that you slice the model down to a 1/12 symmetry model. That way you can have three planes with zero normal displacement making for a very uniform support for the outer part. With much reduced volume, you can use much smaller elements. Make sure you are using quadratic elements that can represent curvature.
- The topic ‘Conical pin contact pressure’ is closed to new replies.
2768
959
825
599
591
