June 27, 2022 at 7:01 pm
sbh5655
SubscriberHi, I am trying to create a model for cross-sectional ultrafiltration. I have a wall with finite thickness to represent the membrane. When I tried to make it a porous zone, I am not sure how I should set my direction vector using conical coordinate system. Can anyone explain how it works exactly?Â
I am really lost with the coordinate system, since my model is a cylinder, but I am using cartesian. Thank you!
June 28, 2022 at 10:58 am
Forum ModeratorIf the wall is "thin" ie wall & wall shadow pair then you have a porous jump and there isn't a conical option.
If you have a fluid region you will have access to the porous media model. The axis etc for the conical option is set in the cell zone refrence values: first tab in the cell zone, porous media is about the 4th tab.Â
- The topic ‘conical coordinate system for porous medium’ is closed to new replies.
- affinity not set
3892
1414
1241
1118
1015
