Preprocessing
Preprocessing
Computer freezes
    • mekafime
      Hello everybody,
      Please could you help me with a problem?, when I reduce the mesh size less than 2mm in a model the computer freezes, I already tried in two computers and the same happens I have research license, I even generated a sphere for only reduce the meshing in the critical area and leave the rest of the model in a larger size (with which it simulates correctly). What can I do to solve it, since there are other users that use smaller mesh size and their computer does not freeze during the simulation?
      I assume you mean the minimum cell size. Check the smaller size isn't trying to capture very small edges or faces in the model: that can cause the cell count to increase significantly higher than you're expecting.
    • mekafime
      Hi rwoolhou,
      I am reviewing the model but I do not see many elements in edges or corners, the number of elements 51195
       is and nodes is 232244
    • Keyur Kanade
      What is meshing method?
      Please try patch dependent tetra.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
    • mekafime
      Hi kkanade,
      Hex Dominant Method
    • Keyur Kanade
      Few things to consider.
      Student license has limits.
      Structural Physics: 32K nodes/elements
      Fluid physics: 512K cells/nodes
      Please check your RAM. Usually 1GB can produce approx 2-3M cells depending on geometry and size functions used.
      Please try to reduce your problem by reducing geometry.
      Also check sizing controls.
      https://www.youtube.com/watch?v=w4q6q8nKF3U
      Keyur
Viewing 5 reply threads
  • The topic ‘Computer freezes’ is closed to new replies.
